HP T1700dr
  • Hoosierdaddy
    • Oct 2016
    • 181
    HP T1700dr
    The machine is acting weird. Put a full set of HP Inks (standard capacity) Says Incompatible ink cartridge (all 6 Cartridges) It is also saying to replace the middle Print Head (which i have installed also) and it didnt change the Message Any Help would be Very Appreciated!! It goes thru the ink loading process and goes back to the Incompatible Message
    Thanks in advance for any help or suggestions
    Hoosierdaddy
  • Kiran Otter
    • Dec 2013
    • 1113
    Re: HP T1700dr
    Could you provide the exact model number from the front panel, and the part number of the ink cartridges?
    You could have ink designed for another country, or a 'contractual' printer (model number ending in F) which can not use normal HP inks. The F model inks have an X in the part number.
    If you have an X in the ink part numbers, and an A model printer, they too won't work with each other.
    Kiran
