HP 4250/ Continuous prints
  • cucuklotz
    • Mar 2007
    • 611
    Hi
    Whether you print from computer(any one) or if you do a test print(For example Configuration page)it keeps making prints never stopping until your able to somehow cancel job. It does this every time.Is there a program I need to reset?
    Thanks Andy
  • OMD-227
    Have a closer look at that configuration page and check what the 'Copies/prints' count is set to. If someone has a play with the seetings, it would be easy to change the default from 1 backwards to 999 with one key press. Change it to 1 as it should be, so you only get 1 copy of your print job. Its the same with most machines.
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      I must agree with wazza. That was a call for me last week. Someone got in the control panel of a 9550 and change the default to 32,000. You can really waste a lot of paper that way.
      • CanonHPTech
        • Apr 2007
        • 235
        Think this was also a symptom of the buggy JetDirect 615 cards if I recall correctly. Is there a 615 installed? If so can you swap it with another card from another printer? Otherwise the JetDirect might be on the Formatter which you might be able to reinit.
        The glass maybe half full, but less is more...
        Printer + Fax + Copier = Jack Of Many Trades,
        but Master Of None
        Color Copier = Not A Color Printer
        InkJet MFP = Not A Fax Machine
        B/W Copier = Not A Press
        Finisher = Deal Closer (salesman, not accessory)
        Copier Tech = Admin's Stress Ball (Scapegoat)
        • cucuklotz
          • Mar 2007
          • 611
          HP 4250 /continuos copies
          HI,
          Thanks for giving me possible soloution to problem,I have not been to customer again,I will be going Tommorrow. Ill let you know how it turns out.
          ANDY
            • 23006
            I've seen that on a HP LJ4200 at the high school. Some smart student bumped up the number of copies to 999. =^..^=
