HPclj 5500
  • Peter Sim
    • Sep 2008
    • 445
    HPclj 5500
    Hai all,need help.
    Is there any guide line on how to fix the ITB unit for HPCLJ5500?
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    As far as HP is concerned the only way to fix it is to replace it. That is all you can do.
    • Peter Sim
      • Sep 2008
      • 445
      Thanks for your reply.Actualy im copier tech,im not familiar with hpclj5500 machine, my friend wanted me to help him to fix the ITB unit because the machine is out of warranty,he already order the unit to be replace.Any advice on how to fix the unit?Thanks.
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        When you say fix, what do you mean? Did you have an issue with it or did the machine ask for one? If the machine ask for one, the reset is in the menu. So new or old you will have to tell the machine you changed it. In the menu, there is a section for resets, it is easy to find because HP made it for an end user to do. If you had any other problem, throw it away and put a new one in, HP did not make them to be repaired. About the only problem I have ever had with an HP belt is when the machine starts throwing out blank paper. The solution...Change the transfer belt. Also the belt would be a supply item on any machine and not covered under warranty. It probably has a life of about 120,000 to 150,000.
        • Peter Sim
          • Sep 2008
          • 445
          Thanks again.The belt is torn,so need to replace with new one.when i replace ,should i reset the belt counter and do adjustment?
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            Just reset the counter, the machine will adjust itself.
            • Peter Sim
              • Sep 2008
              • 445
              Thanks.
