HP 4200 tray lift
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    HP 4200 tray lift
    I am working on a 4200 that the tray will not lift on. I replaced the lift motor and it still will not work. It plugs into the DC controller so that would be my next thing to replace, however since I can't return the DC controller if I buy it, I was wondering if someone else has had this problem.
  • mo0651
    • 1054
    You guessed rite. That is the board. Had one of these. motor was cheap but not the problem.
      • 30300
      TRAY
      Have you install another tray and see if it worked?
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Yes I swapped trays first. I just did not want to find out there was some magic reset I did not know about, I have had a lot of firmware issues lately on HP. Thanks for the replies.
        • CanonHPTech
          • Apr 2007
          • 235
          I also believe you are on the right path... been awhile, but I think I had one of these also a long time ago. A init wouldn't hurt, but I don't think that helps with mech failures on HP's all that much. Let us know how you make out.
          The glass maybe half full, but less is more...
          Printer + Fax + Copier = Jack Of Many Trades,
          but Master Of None
          Color Copier = Not A Color Printer
          InkJet MFP = Not A Fax Machine
          B/W Copier = Not A Press
          Finisher = Deal Closer (salesman, not accessory)
          Copier Tech = Admin's Stress Ball (Scapegoat)
