HP 5500 heater not working.
  • jeff33
    • Aug 2009
    • 61
    I have a HP 5500 that the heater won't come on. I checked the V on the main PCB and have about 36v to ground on both pins. I assume that it uses ground switching. When the print starts there is no change in the voltage readings. Is there anything besides the main board that controls the heater? Any ideas on whats wrong other than the main board. Any thoughts would be helpful. Also I ohmed out the heater and got about 12 ohms. They use a rip but I made sure the heater was enabled. Thanks Jeff
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment
    from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • Rob Sandberg
      • Jul 2008
      • 275
      Jeff
      Is the printer showing any errors?
      Why do you suspect the fuser (heater)?
      Follow Paul's advise and get a service manual for this printer.
      If the fuser is bad the manual will be needed for replacement.
      :for Paul
      See Paul someone does think you are good for this site.
      Rob S
      • JustManuals
        • Jan 2006
        • 9838
        Many thanx!
        • jeff33
          • Aug 2009
          • 61
          This is a designjet plotter, it has no fuser the heater is to help the ink dry on the plot. I have the service manual for this plotter but it has very limited information on the heater.
          • fixthecopier
            ALIEN OVERLORD
            • 4713
            I have one on my table right now. As soon as I bleed the air out of the tubes I should be ready to print. I can take a look and see if I notice anything, but it may be Monday before I get to it.
            • jeff33
              • Aug 2009
              • 61
              Thanks, Any help would be great. Jeff.
