Color LJ 3550
  • copyman
    Owner / Technician
    • Sep 2005
    • 4664
    Color LJ 3550
    Printing black very light. It is gray instead of black. All other colors are good. Tried new OEM toner & changed the blk dev clutch but did not help.
    Not sure if this is relevant but printer seems to be running slower.
    Any other suggestions? Thanks in advance
  • mjunkaged
    • 383
    Faded colors...
    First, check high voltage contacts at the sides of carts.
    Then it's probably going to be the HV board. I recently had one with the same exact problem, only on Cyan.
    The reason is that it's a HUGE HV board on the side that delivers voltages to all the carts.
    You can call partsnow tech support to confirm
    www.partsnow.com
    for the #
