hp 3600n
  • krm
    • Aug 2009
    • 233
    hp 3600n
    The colors mix improperly, the cyan prints with magenta shadow and repeating image. It happens before fuser and black prints well.
  • mo0651
    • 1054
    Print a status page. See if anything is due to be replaced. What is the page count. Sounds like bad drum or transfer. Are you using OEM cartridges?
    • prntrfxr
      • 1622
      hp 3600n
      check your event log see what you see.
      do a half page test. - is it occurring before it goes into the fuser?
      more than likely its a transfer belt though.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • krm
        • Aug 2009
        • 233
        hp 3600n
        Thanks to all replies. It happens before fuser, I will recommend belt.
        • prntrfxr
          • 1622
          hp 3600n
          print a configuration page and you will see what looks like little L's in the corner. Each L will be a different color and should be the same distance. The movement of the color you are seeing could be related to color plane registration. Clean the color plane registration sensor and density sensor. Clean all the cartridge contacts and replace any suspect cartridge. Failure of this sensor will cause 54 errors (check event log), blurred images or offsetting of color/s.
