Colour Laser HP5550
  • pinheiro
    • May 2009
    • 51
    Colour Laser HP5550
    I got a HP 5550. I can ear the fans and motors but no display at all. I have test all boards in working mc and it's look perfect. Can someone help???
  • prntrfxr
    • 1622
    Colour Laser HP5550
    Did you...
    Disconnect and remove all optional equipment, then power up machine?
    Remove and reseat firmware/memory?
    Remove and reseat the formatter board?
    Replace Display Panel?
    • ExOceMan
      • Sep 2009
      • 63
      Think there could be something on one of the sensors causing this issue. I know with many of the other hp products there are concealed sensors that can get media stuck on/at them and cause a hidden jam. May want to pop your paper path apart.
