HP 2015?Low toner issues
  • cucuklotz
    • Mar 2007
    • 611
    Hi,
    Machine is saying ;low toner even though cartridge is new.I have tried several different cartridges(not just one distributor OEM + COMPATIBLE).It may run 10-20 copies and then it comes on again. I take cartridge out and shake it and it will work for a few copies before it happens again. Machice is perfectly leveled and and everything seems in tact. Any help would be appreciated.
    Thanks Andy
  • prntrfxr
    • 1622
    Clean the HVPS contacts in the machine that touch the cartridge. However, there is a known problem with the formatters on these machines, causing LED lights to stay on is one of the symptoms. I would try replacing the formatter 1st on this printer. Your problem may go away.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • cucuklotz
      • Mar 2007
      • 611
      Hp 2015/low toner
      HI,
      Thanks for helping me many times and once again.I will speak to customer today to see what they want to do.
      ANDY
