HP CP3505 error 13.01
  • Realtech
    • Oct 2009
    • 103
    Hi my colorlaserprinter is not feeding paper from tray 2 & tray 1 and error 13.01 appear on the display.
    Turn printer on printer is in ready mode than select to print a configuration page. engine started running than a error 13.01 appear on the display yhis happen with tray 1 also. any suggest ?
  • prntrfxr
    • 1622
    Sensor/flag/obstruction in the path could be your problem. The error should tell you where it is. "13.01.00 JAM IN TRAY 1" would mean you have a problem in tray 1 for example. If there is something in the path, the printer will go straight to the error regardless of what tray you're trying to print from. Once you know which tray, move the flag to see if it moves freely. Check for debris or an obstruction in the paper path. Run the manual sensor test from the diagnostic menu. You will need to know where each sensor is and what letter the printer has assigned for it. Send your email address in a PM to me and I'll send you just that page from the service manual or you can purchase a service manual for the machine, which would be even better.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
