Reliable HP Fusers
  • Kurt
    • 56
    Reliable HP Fusers
    Looking for a reliable Hp fuser for 4200.......had bad luck with fusers from
    TSA and Parts Now......Thanks, Kurt
  • CanonHPTech
    • Apr 2007
    • 235
    Try MetroFuser. Metrofuser- Parts for laser printers- fusers, kits and more 1-888-FUSERS-1 or 1-888-387-3771. Had better luck with them. They use Anti-tear Films in their LJ 4200 Fusers, and it seems they also now use them in 1300/5500 series. Smaller company than Parts Now. You will still get a 'quick ripper' here and there, but that is expected with that series and they will go to bat for you since they are a smaller and customer focused company. Good luck.
    The glass maybe half full, but less is more...
    Printer + Fax + Copier = Jack Of Many Trades,
    but Master Of None
    Color Copier = Not A Color Printer
    InkJet MFP = Not A Fax Machine
    B/W Copier = Not A Press
    Finisher = Deal Closer (salesman, not accessory)
    Copier Tech = Admin's Stress Ball (Scapegoat)
    • nightshade
      Chromographic Supremesist
      • 158
      We use LMI for HP supplies. Fusers are good, but color supplies seem to be lacking. Only good thing is that they guarantee their stuff for the expected life as set by the Mfgt. So if it only goes 3/4 life.....FREE replacement.
      But I don't have any contact info....sorry.
      • LaserSharp
        • Sep 2007
        • 94
        There was found to be a bad angle on the bushings used to hold the film on one side a while back..the tearing issue was a result, you SHOULD be able to get reliable fusers just about anywhere now.
        • Walter Chavez
          • Oct 2007
          • 14
          Try Motek @ 972-242-1203
          • lkrsardis
            • Dec 2007
            • 316
            good fusers
            we use a company called sunflower repair
            800.373.0611
            i have had only one failure out of approx 75 fuser kits hp and lexmark
            Like the United States Postal Service It's a miracle it works!
            • sunpartskevin
              Fusers and MK's
              If you need fusers please contact me. I'm a Sales Rep for Sunflower. 1-800-373-0611 ext 110 ask for Kevin I can help you.
              Thanks,
              Kevin
              AIM: sunpartskevin
