Hp laserjet p3005dn printer
  • Dimpo
    • Aug 2009
    • 104
    Hi
    I am having error (jam inside rear bin)on my hp laserjet p3005dn.I need help as to how to clear this error because all the paper sensors a ok and i think its a software problem or the formater board which is fault.If anyone knows how toreset this machine please help.
    Best regards
    Dimpo
  • prntrfxr
    • 1627
    The error is either present or not. When you have corrected the problem, the error will go away. It doesn't stay in memory, so can't be reset or cleared. If the formatter is at fault, when you replace the formatter the error will go away.
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
