CP 3525 Error
  • donley
    • Aug 2025
    [Error Code] CP 3525 Error
    I have a CP 3525 color printer and I installed 3 new fusers in this printer, and I still get error code 50.4 It takes about a week before the error shows up.
  • Rob Sandberg
    • Jul 2008
    • 275
    Is the AC plugged into the wall outlet or a power strip?
    Make sure it is plugged into the wall.
    What is the media weight?
    From the service manual.
    50.4 FUSER ERROR The fuser driver circuit has experienced an
    error.
    1. Check the power source. If a power
    generator is used, improve the situation.
    NOTE: If the product does not meet
    the power requirement of 43 to 67Hz
    frequency, the fuser temperature control
    does not work, which causes a
    malfunction.
    2. Reconnect connector (J101) on the DC
    controller PCA.
    3. If the problem persists, replace the lowvoltage
    power supply. See Low-voltage
    Rob S
