Hp printer?
  • ashsmith
    • Jul 2025
    Hp printer?
    I used a non hp ink cartridge and now the printer won't work. Do you have to use HP products?
    also,
    How do I set up a HP printer to count the number of sheets that different computers print?
    I would like to network my printer so that I can count who prints a certain number of sheets. Is there software or a function on HP printers to do such a thing?
  • OMD-227
    also,
    It generally helps to use HP products in a HP machine..... There are hundreds of different brands of generic inks out there, but none should cause your machine not to work, unless the cartridge itself is faulty, or there could be something else wrong. The model number would help.........
    As for monitoring prints...... use Papercut. PaperCut - Print Logger - a free print job logger for Windows. I've seen a few people use it, and it seems OK.
    • ashsmith
      Its HP p1005, thanks for links. I'll check the cartridges.
