MFP LJ2727 serial #...
  • Bolivia
    • May 2010
    • 22
    I am wondering if anyone knows how to input the serial # after replacing the formatter board.. It is usually in the Service menu on most..This one does not have it..Thanks in advance...
  • prntrfxr
    • 1622
    This is basically the P2015 printer with flatbed scanner attached. That means you will have to use commands to enter PCL code in HP Webjet Admin.
    I found this set of commands for serial number & page count. I haven't tried it, so I don't know if it works. Please reply either way to help us:
    %-12345X@PJL JOB
    @PJL SET SERVICEMODE = HPBOISEID
    @PJL SET SERIALNUMBER =
    @PJL SET PAGES =
    @PJL SET SERVICEMODE = EXIT
    @PJL EOJ
    %-12345X
    or
    %-12345X@PJL DEFAULT SERVICEMODE=HPBOISEID
    @PJL DEFAULT SERIALNUMBER=XXXXXXXXXX
    @PJL DEFAULT SERVICEMODE=EXIT
    %12345X
    Also these commands must be sent via USB not FTP. They can be sent via LPR command to the IP address. For more information to understand how to implement these codes, it is possible to download the PCL Reference Book (google it). Please reply whether or not it works and what you did, so it will benefit others.
    Last edited by prntrfxr; 06-08-2010, 05:55 PM. Reason: added another set of commands & more info
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • Bolivia
      • May 2010
      • 22
      Thanks Prnt... I just left it alone and and recorded the s/n imprinted on the tag.. Just thought it may have been on another menu I did not know about.. That is a little too technical..lol..
      • prntrfxr
        • 1622
        I completely understand. I believe there is an escape code that has to go in front of the % anyway, but it used to be operating system specific and I would have no idea what to tell you to do to enter it. This was asked before with the P2015 but I didn't have time to even research this much. It is a question I get asked a lot here too. I hope it helps someone who needs to do it. This is one of the perks of working as an in-shop tech for a vendor, I don't have to do this.
          • 23008
          Your printer job language looks right. LPR jar would probably be the easiest way to send the command If it uses TCP/IP. =^..^=
