H/P 4100 mfp and no faxing issue...help!!
  • landspeeder
    • Feb 2010
    • 355
    A customer of mine has a 4100 mfp...the other day they had a EIO 1 disc error...so we changed the hard drive.....it will act as a printer and copier but will not fax....the Fax module on the side of the machine has the "red" error lite on....and it does not display faxing as a option on the 4100's display...the last 3 errors on the config page are: 68 1F20, 68 3D04 and 81 88D4...so my main concern is to get the fax portion working asap......thanks!!!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
    • 23010
    I think prntrfxr will confirm this. I had a similar issue on a HP LJ4345 recently that turned out to be the formatter PWB. The fax option plugs directly into the formatter, and if it is not recognizing it, there are not any other options. =^..^=
    • landspeeder
      • Feb 2010
      • 355
      The more I read into it ...things point to the formatter board...so from what I understand parts of a formatter board can be functional and other areas not.....so a jet direct card will work but the Fax module which plugs to the par port on the formatter board will not.... so should I also get another firmware module with the board?
      • prntrfxr
        • 1622
        4100 series printers have a weakness with the formatters. We sell more of them for the 4100 that any other part except the trays and the fusers. If the firmware version is old, I would replace it. This has been a 4100mfp kind of day. I've had 2 other tech support calls and then this. I guess things run in 3's.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • landspeeder
          • Feb 2010
          • 355
          Thanks for the input...any places that you can recommend to purchase the board? Up here in cdn they are pricey and down there they are pricey
            • 23010
            Try TSA World they've done right by me.
            TSA World - Product Catalog
            And yes, you can lose a single function, and the rest of the machine still work. That's the rule, not the exception. =^..^=
