Hp 1050-c designjet
  • auburn business systems
    owner/technican
    • Mar 2009
    • 46
    [Error Code] Hp 1050-c designjet
    this plotter is giving me a "clear printhead path turn off (1) "error message. looks like the printhead cleaner unit "service station" is not allowing the carrage to go in/out of it. any ideals? looking at the service manual but it does not get into this error. 1. could it be the incoder strip? 2. replace the service station? 3. just clean the service station? any help on this wuld be great thanks howard auburn business system's
    • 23010
    On this model the mechanical aspects of the service station get gummed up with the sprayed waste ink, and cease to move smoothly. I'd start by removing the service station. Remove the large gobs of ink, then clean the remaining parts in the hottest water that you can stand. It will look like new, and work a whole lot better. =^..^=
    • mo0651
      • 1054
      Yep and I would clean the rail the carriage slides on while I was at it. Lube with 3n1 oil or something light weight like it.
