Hp Laserjet 4345 mfp makes loud banging or knocking noise.
  • rdavisalan@gmail.com
    • May 2009
    • 40
    Has anyone experienced a loud banging or knocking noise while printing? Prints come out fine, the sound remains no matter what tray I print from. No error codes.
    I tried swapping a toner cartridge and removed the rear panel checked those gears and even turn the motors by hand. I don't have much experience with this unit can someone help? Thanks in advance.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • 10871087
      • Jan 2005
      • 1062
      it's a noise coming from a 2x2x2 box, track it down.
      • prntrfxr
        • 1622
        Lift motor/tray issue if it is coming from that area.
        Scanner bed assembly if it's coming from the top
        The printer is basically a 4250 with a scanner on top.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
          • May 2009
          • 40
          I ran the different components in the diagnostic menu and the sound starts when I run the main motor or feed clutch. I was thinking it was a tray lift motor issue too, but its constantly making the noise from start of the print to the end. Have you experienced this before?
          • mo0651
            • 1054
            Pull the fuser. Look for worn bushings or drive gears.
            • prntrfxr
              • 1622
              I still think it's the lift motor or the tray, but I've been wrong before.
                • 23010
                I agreed with mo0651. Eventually you'll get jamming on the bed area. It's called the swing plate. Effectively it's the fuser coupler gears that wear down to nothing. I've got one machine in need of it now, and it looks as though it's going to be really unpleasant to change. =^..^=
