hp 9000 mfp
  • Tom
    • 344
    hp 9000 mfp
    Hello, got a problem with a machine that I'm only mildly familiar with. I know all the lower end hp printers well, but this 9000 is a bit more intense. Getting a code 50.2, which is a fuser code. Had one laying around that I know works, same problem. After bypassing the side door & watching it, I can see that the heat lamp in the lower fuser is not coming on (heat lamp in upper work fine & cycles properly). I have access to a part machine, so I tried swapping main board, no help. Reconnected all connectors throughout machine looking for loose connection (also jet direct & hardrive) no help. I don't see any blown fuses. Any ideas, I'm thinking power supply next.
  • prntrfxr
    • 1622
    Replace Low Voltage Power Supply
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Tom
        • 344
        power supply fixed it. thanks
