Design Jet 1050C Plus
  • iscott
    • Mar 2010
    • 344
    Got a 1050C Plus
    Was getting a check printer path error 2 (I think) replaced the belt and adjusted the printer
    Head (by the way it took 2 weeks to get that damn little tool from HP I recommend finding it in stock some where else.) Fired it up and after awhile I got a paper loaded incorrectly message.
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
    Paul@justmanuals.com
    • fixthecopier
      ALIEN OVERLORD
      • 4713
      The back panel does not matter. It can really be a bitch to get the paper straight. I may have to try 7 or 8 times. Make sure the roll is tight and use the blue lines on the right side of the deck.
      • Ducttape n Glue
        • 195
        I have a 1050 sitting in front of me now. If you need a talk thru let me know. Also check the black hub on the RH side of the paper spindle and make sure it is seated fully to the right and then check the roll to be sure it is fully to the right. This is a front load unit and needs to align with the white line first and then the blue line as it exits the path.
