HP Design Jet 1050C Check Printhead Path Type 2
  • iscott
    • Mar 2010
    • 344
    I have replaced the Drive Belt and adjusted the print head height using the HP gauge.
    Still getting the check Print Path error type 2.
  • fixthecopier
    ALIEN OVERLORD
    • 4713
    If when changing the belt, you did not clean the old rubber out of the teeth of the pulley that drives the belt, it can cause the belt to skip. I assume you cleaned and lubed the rails.
      • 23002
      What a pain! I have a toothbrush just for scrubbing the loose bits of rubber out of the timing pulleys, and a dental pick to the more resistant bits. =^..^=
      • fixthecopier
        ALIEN OVERLORD
        • 4713
        Yep, either a good wire brush or the tip of a knife blade.
        • iscott
          • Mar 2010
          • 344
