Hp Laserjet 4100mfp Not Displaying
  • Dimpo
    • Aug 2009
    • 104
    Hi
    Am having a problem with my Hp laserjet 4100mfp printer having a BLANK DISPLAY but the machine initialises>Is there someone who have came acros this problem and how did you solve it?If someone have a technical manual you can email it to nrsmoyo@yahoo.com
    Please help am stuck please.
    Best Regards
    Dimpo
  • kingpd@businessprints.net
    • 919
    Can you actually print to it? How about copy?
    • prntrfxr
      • 1637
      ADF power supply (not the printer power supply). There is a weakness in these units for the power supply in the ADF to go bad. The display panel plugs into it.
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • bojans
        • 1313
        I have this one in service. When I remove memory and turn on, it has blank display, but initializes. Could bad memory cause this problem?
        • landspeeder
          • Feb 2010
          • 355
          the scanner power supply is the cause, change it and it's fixed....and thats all she wrote!
          You never realize how cheap a professional is until after you let an amateur do it.... and
          if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
          • montana
            • Aug 2008
            • 393
            hi...yes it could be a bad memory..i agree with mr.bojans
            good luck
            • bojans
              • 1313
              I don't have ADF on this model, it's only printer, and has same problem with blank display.
              • landspeeder
                • Feb 2010
                • 355
                try another display 1st
                • bojans
                  • 1313
                  It happens once in a week
                  • landspeeder
                    • Feb 2010
                    • 355
                    loose connection or maybe a cold solder joint
