H/P LJ M2727 NF scanner failure number 5
  • landspeeder
    • Feb 2010
    • 355
    I just replaced the scanner assembly about 3wks ago for this same error (5)...is there possibly any other cause or is it just the weak poor quality scanner failing again? Customer is a bit bent needless to say....paid us close to $400. p and l
    thanks all!
    You never realize how cheap a professional is until after you let an amateur do it.... and
    if this was an easy thing to do then everybody would be doing it! But it isn't and they are not!!
  • GC-SCO
    • 26
    you will more than likely have to replace the formatter aswell. When the scanner motor fails it tends to take out the formatter. Have had to do this loads of times
      • 23009
      Ouch! That will be difficult to explain to the customer. To appease the customer I'd give the formatter at cost, and throw in the labor. =^..^=
      • landspeeder
        • Feb 2010
        • 355
        Hey BC4866...Ouch is putting it gently........who's got a used formatter..where's my coffee?
          • 23009
          Just so ya know, you don't want a used formatter. This series had a huge issue with formatter boards. The chances of you getting a bad board are very high. =^..^=
          • GC-SCO
            • 26
            update the firmware to the latest level also. If the machine is less than a year old HP should cover this with a warranty.
            Sorry to be the bearer of bad news.
            • landspeeder
              • Feb 2010
              • 355
              from what I understand she was 1 wk out of warranty when she called H/P and got a flat "to bad" ...whats the cost in the US for a formatter board?
                • 23009
                $300. Less if you have an account.
                HP LaserJet M2727NF MFP Boards
                • landspeeder
                  • Feb 2010
                  • 355
                  after talking to PC Parts in Toronto and weeping on the phone...they will sell one to me for $170.
                  They customer wants me to eat it of coarse.....right!!
                    • 23009
                    Don't do it man. Labor sure. Profit maybe. But not the part cost.
                    Only if you had inadvertently caused it, which you didn't. =^..^=
                    • landspeeder
                      • Feb 2010
                      • 355
                      if I claim the scanner under warranty whats the odds it will work amd maybe the formatter is alright?
                        • 23009
                        IMHO the odds are against you. =^..^=
                        • GC-SCO
                          • 26
                          Generally what happens is the scanner motor fails causing the formatter to go. What we found in the early days of working on these is we would replace the scanner then have to replace the formatter as well. We tend just to fit both now when we have scanner failures. There is a very and I mean very slight chance that if you leave the new scanner on and update the firmware it might work( the firmware is updated on a regular basis available from HP.COM). If you replace the formatter the machine meter reading and serial number will no longer be there. There are prn files that you can re-input these with if HP will give them to you. These machines are a pile of cack and more hassle than they are worth. It may be cheaper in the long run to buy a replacement and rob the parts you need,or if you have one thats in warranty you can claim the formatter from that..
                          • landspeeder
                            • Feb 2010
                            • 355
                            well I'm off to do calls...thanks for the input!...till tomorrow
