HP LJ 2300L
  • iscott
    • Mar 2010
    • 344
    HP LJ 2300L
    Error Code 49.306
    Any Ideas?
    • 22930
    49.xxx codes are listed as firmware errors in the manual, but most often are caused by corrupt data arriving at the printer. Sometimes it's a specific document. Sometimes its a driver issue. Sometimes it's a network issue. I've seen all three at one time or another. The only thing I haven't seen is an actual firmware problem. =^..^=
    • prntrfxr
      • 1627
      Blackcat is right. Haven't seen too much of an issue with 2300's. Check what he says first. If it isn't that it will be:
      Firmware (may be actual Firmware DIMM that's bad)
      Formatter
      or both firmware and formatter
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • JustManuals
        • Jan 2006
        • 9838
        This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
        Paul@justmanuals.com
        • kingpd@businessprints.net
          • 919
          If you need second hand parts or a whole printer of this model, I have a ton of them I'm looking to liquidate. I don't have any toners though so they wouldn't be included. HAHA!
          I might even have a few junkers, if so you can just have the part. I'll have to check on Monday though.
