CLJ3505 printing slow
  • Oldslap
    • 27
    [Misc] CLJ3505 printing slow
    I have a CLJ3505 that intermittently prints slow, maybe 3-4 ppm instead of 12. It does this with prints over the customer network, also when patched into my laptop and when generating internal prints (config etc). I am also having difficulty performing a cold reset. I will be trying a new formatter, but am not convinced that this is the problem.
    Any ideas?
    • 23009
    You might try changing the image memory first. =^..^=
    • JustManuals
      • Jan 2006
      • 9838
      This Parts & Service manual can now be purchased for $11.77 and downloaded immediately after payment from The Internet's largest collection of manuals
      Paul@justmanuals.com
      • Hank
        • Aug 2009
        • 25
        Suggest you check the paper menu. Make sure the machine is not set for heavy paper > 130gr/mt2 ,better yet, put everything back to factory setting and try again.
        Hank
        • prntrfxr
          • 1622
          Is it slow when you print from other PC's?
          If the dpi settings in the printer driver are set high it will print slower, lower = faster. Check paper settings in driver as well. Remember software will always override hardware.
          If it is slow from control panel, memory might be a likely cause. Also, upgrade firmware. There have been some weaknesses with the formatters on this machine.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
