HP designjet 500 "Maintenance advised"
  • Zajon
    • May 2025
    [Error Code] HP designjet 500 "Maintenance advised"
    On a designjet 500 of a my customer appears this message "Maintenance Advised".
    Service Manual says "spittoon in the service station is full". i must replace this part.
    i will replace the spittoon and service station...
    how can i reset to zero the usage counter of this part? and disapper the Maintenance message?
    thank you guys!!
    Cheers
  • PsychoPod
    Press the ↑ or ↓ key until the front panel displays the Setup Menu and
    then press Enter.
    Once inside the Setup Menu, Press the following key combination ↑ + Enter
    to access the special Service Menu.
    After that navigate through menu to Reset usage counter as your carriage has passed 6000000 cycles.
    • Zajon
      then press Enter.
      thank you, u are great!!!
      i will try this procedure in the next week...
      cheers!
