HP4250n
  • RicohTech
    • Oct 2007
    • 30
    HP4250n
    Hi all.... I don't work on these but they have me going out to service this HP printer! Does anyone know how to take it apart? It is causing lots of lines all over the page. Suspect fuser? I was told that they changed out the drum/toner unit already.
  • just a tech
    • Jan 2007
    • 332
    here ya go...good luck http://www.feedroller.com/Store/Serv...4300)%20sm.pdf
      • 22927
      In the order of likelyhood:
      1) laser cartridge (doesn't matter if its new)
      2) fuser film
      3) transfer roller
      4) dirty laser optics/mirrors (only if it was in a dirty environment, usually the covers give it away). By the way, don't touch the reflective surfaces of the polygon mirror. You can use a blower brush. The polygon mirror surfaces scratch very easily. I ruined one with a Q-tip.
      • RicohTech
        • Oct 2007
        • 30
        Thank you
        Super! Thanks for the pdf of the manual!!! This will be invaluable to getting this fixed!!
        • RicohTech
          • Oct 2007
          • 30
          Lots of lines on the copies
          Blackcat....
          I asked her if they replaced the toner/drum cartridge and she said that they've put in a couple already and they still continued to have lines thru out the page. I'm betting on either fuser or xfer roller. I dont' know how many pages they have on it... Just a tech sent me a link and that manual is great! I've never seen an HP manual before, but its just getting used to the format.
          Thanks for you input!!
            • 22927
            Of all the manuals I've used I'd have to say HP is written the best. Understandable, complete, and English! Good luck.
