4730: after f/w upgrade, web interface no longer detailed!
+ More Options
Posts
  • BWB8771
    • Mar 2011
    • 49
    Prior to the upgrade, I could view/edit the fax address book, as well as view/edit a great deal many more options.
    Is this behavior by design?
    HP JetDirect: J7949E
    Firmware Version: V.33.21
  • The Fixer
    • Dec 2005
    • 22
    Did you get the FW for just the base unit? You will need the MFP FW.
    Is it a CM model? Let the HP site install it if it will auto run.
    • BWB8771
      • Mar 2011
      • 49
      That's what I'm guessing I did: just update the JetDirect module. I'm d/l the HP Color LaserJet 4730mfp Printer Easy Firmware Update Utility now...
      • BWB8771
        • Mar 2011
        • 49
        Well, THAT didn't work... How would I go about finding the update for the *mfp* portion of the printer?
