help me plz
  • walidcharifi
    • Feb 2011
    • 379
    help me plz
    I want to buy an HP plotter
    I found two desingejet 800ps / desingejet 1055plus
    what is the right choice
  • walidcharifi
    • Feb 2011
    • 379
    help
    • prntrfxr
      • 1622
      They are made by the same manufacturer, so the differences would more or less be options or capabilities. Since you have not indicated what you are using it for, how often you will be using it or what you need in a plotter, no one will be able to provide more information than what is shown in the specs.
      HP Designjet 800ps Printer (42 in) (C7780C) specifications - HP Small & Medium Business products
      HP Designjet 1055cm Plus Printer (C6075B) specifications - HP Small & Medium Business products
      Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
      • CanonHPTech
        • Apr 2007
        • 235
        DesignJet 1055's were workhorses from what I remember. They were based on an older 1050 model that was rock solid. Not familiar with the 800's, think they were a little newer.
        The glass maybe half full, but less is more...
        Printer + Fax + Copier = Jack Of Many Trades,
        but Master Of None
        Color Copier = Not A Color Printer
        InkJet MFP = Not A Fax Machine
        B/W Copier = Not A Press
        Finisher = Deal Closer (salesman, not accessory)
        Copier Tech = Admin's Stress Ball (Scapegoat)
        • jeff33
          • Aug 2009
          • 61
          The 1055 is faster and has more options, but some parts are not available from HP so I would stay away from it. The 800 is a very good plotter and they last a long time, parts are readily available from HP. If it was me I would go with the 800
          • NebTech
            We use the 800 in our print center. They are very dependable and last a long time.
