4345 mfp
  • ucinn
    • Jun 2009
    • 383
    4345 mfp
    every time you fax, it comes up with the message "Do you want to continue with these settings" Is there a way to get rid of this message and just have it fax? The customer is annoyed with it but I couldn't find any way to turn it off.
    • 23009
    Perhaps there is no TTI information programmed? How hard could that be? =^..^=
    • ucinn
      • Jun 2009
      • 383
      That's all programmed in there.. it's asking if you want to use the settings.. I'm guessing like the dpi and such.
      • prntrfxr
        • 1622
        Probably something in settings that can be switched on or off. Service manual says nothing about it, only this:
        "For complete information about troubleshooting fax problems, see the HP LaserJet Analog Fax
        Accessory 300 Service Manual."
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • TommyH
          • Sep 2009
          • 118
          Kind of a late reply but I think you have to do this in the EWS. If you log in to the EWS and go to the "digital sending" tab. Than click on "preferences" bottom left menu. At the bottom of this you will see the following below. I believe if you change this to reset immediately this should give you what you are looking for. I know it works like that for email, not sure on the fax have not tested it. Best you can do is try it and see.
          Auto Settings ResetAfter a Digital Sending operation is complete. Immediately reset the device to the default settings. Delay before resetting the device to the default settings.Number of Seconds (10-300) to delay:
          • ucinn
            • Jun 2009
            • 383
            Thank you TommyH... that was it.
            • TommyH
              • Sep 2009
              • 118
              no problem, good to hear it worked out.
              • ucinn
                • Jun 2009
                • 383
                Oops..spoke too soon. That works, but I have on 4345 that has a different web interface page that doesn't have that tab.. it just has two tabs, home and network. it also has a green skin to it instead of blue. They both have the same imbedded jet direct model and firmware. The machines have the same firmware, but the web interfaces are different. How do I correct this? Is there a way to upgrade the web interface?
                • TommyH
                  • Sep 2009
                  • 118
                  The only thing I have found that fixes this is a DISK INIT. Let me know if you don't know how to do this. Or if you find something else that fixes it
                  • ucinn
                    • Jun 2009
                    • 383
                    I will give that a try..thanks a bunch for your help.
                    • ucinn
                      • Jun 2009
                      • 383
                      I tried the disk init and nothing, still the same EWS screen with just two tabs and green skin. I can't figure this out. I also updated all the firmware to no avail.
                      • TommyH
                        • Sep 2009
                        • 118
                        Maybe a cold reset with a disk init at same time. I have seen a cold reset work and than sometimes not work. Also have seen a disk init work and sometime not work. Most instances I have ran into with this has been resolved with a disk init.
                        I would try to do a CR and disk init at same time. Ya firmware upgrade has never worked for me with this issue.
                        • ucinn
                          • Jun 2009
                          • 383
                          Cold reset did the trick. Thank you once again TommyH.. if i ever meet you, the drinks are on me.
