HP-(CLJ)4500DN tries to feed from 1st tray without paper loaded
  • John Sasser
    • Mar 2011
    • 37
    [Jamming] HP-(CLJ)4500DN tries to feed from 1st tray without paper loaded
    What I have dond so far is-I switched that whole drawer assembly out, that houses the transfer kit, but still the same symptom exist. This is happening when using the op panel to print logs/menus & things. I dont have this connected to anything, But ALL of my other 45's feed from the #2 trays. What different? thanks,
  • Old Copier Doctor
    • Apr 2011
    • 13
    Is this just a configuration issue? Check the tray 1 configuration. You don't want to default to feeding out of it 1st.
    • Wild Bill
      • Jul 2005
      • 774
      If it is trying to feed from tray 12 and there is no paper it indicates that the paper present sensor lever/flag is activaited all the time. Broken/popped out
      Izzy
      • prntrfxr
        • 1622
        When you print a configuration page, what does list for tray 1 and 2? What paper size? Is the wheel/flag for tray 1 out of position or broken?
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • John Sasser
          • Mar 2011
          • 37
          IT says tray 1 letter/unknown &tray 2 says letter/plain. I know this is correct. As speaking of the wheel sensor unit, I swapped the whole drawer with another--same problem. Whats next?
