HP LJ C5500 stops in the middle of a print job and times out
  • alpha-omega tech
    • 80
    I have a customer with a HPLJ C5500 that will print about 10 pages of a 70 page document then the LCD screen says data received and the printer will stop printing and eventually times out. Any suggestions. This unit has a jet direct card(600). I am thinking it might be the jet direct card but need to know if anyone had this problem out in the field, just to be sure.
    • 23002
    I'd start by resetting the JetDirect, then re-entering the address. =^..^=
    • alpha-omega tech
      • 80
      I did reset the jet direct card and re-enter the addresses and it still timed out during the middle of printing a job.
        • 23002
        Does it show the DIMM Memory on the Configuration Report? Possible failed image memory. You might try to re-seat it.
        • JustManuals
          • Jan 2006
          • 9838
          Just Manuals | The Internet's largest selection of manuals | Instant Downloads
          Paul@justmanuals.com
          • alpha-omega tech
            • 80
            It shows Dimm and I reaseated the Dimm. Today I will get a jet direct and try that.
            • alpha-omega tech
              • 80
              Printer is now working properly after a new jet direct card was replaced with a newer version card.
