HP-LJ 4250
  • otuvak
    • Aug 2010
    • 102
    HP-LJ 4250
    Just replaced a swing plate and fuser drive gear in this machine. Trays 2 and 3 work just fine. When I try to do paper path tests from tray 1 the paper stops right before the transfer roller and throws 13.05.00. Replaced bypass unit from a different machine and same result! Customer said tray 1 was working before I replaced swing plate....I have reordered another bypass unit(don't think that will fix my problem). Is there something the swing plate would affect this? I thought about replacing it but can't see it helping since trays 2 and 3 are working just fine. Any thoughts or suggestions? Thank you!
  • pjdbm
    • Sep 2007
    • 360
    I would back track on this job. Check the connections and look for pinched wires.
    Sounds like you have a harness out
    • JustManuals
      • Jan 2006
      • 9838
      Just Manuals | The Internet's largest selection of manuals | Instant Downloads
      Paul@justmanuals.com
      • prntrfxr
        • 1622
        Only thing that is connected with the swing plate is the toner door (via linkage). When you open/close the toner door, swing plate should move to disengage/engage fuser gear. Other than that, I agree with pjbdm, check the tray 1 p/u asm cable to dc controller. Disconnect and reconnect again even if it looks like it's in good.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
        • otuvak
          • Aug 2010
          • 102
          Replaced bypass unit and upgraded firmware today. Still not fixed but I can manually help paper through without jamming. Replacing reg assembly when part comes arrives. Any other thoughts?
          • faxman28
            • 435
            check tray paper size setting in menu or config page, HP has 13.05(paper not reaching ps108, fuser enterance) can be caused by Tray 1 being set to envelope and feeding letter/legal paper thru. printer would not give paper mismatch error but 13.05 or 13.06 error. also it states a bad fuser(binding, which I have seen) could cause this. I was also thinking sensors didn't get plugged in all the way after the swing plate replacement, but you said tray 2 and 3 work fine.
