HP Laser Jet 2420 With Ghost Image
  • ignacio.cortez
    • Jul 2010
    • 176
    [CQ] HP Laser Jet 2420 With Ghost Image
    I have a client with an HP LJ 2420 that ghosts the image, I replaced the
    fuser unit since most of the time that is what fixed that type of issue on
    my cases, the ghost was still there, after some tinkering and client telling
    me that it had started when they replaced the toner cartridge, I
    recommended replacing the Toner Cartridge, customer ordered more and
    called a couple of days ago stating that the ghost image disappears for
    a couple of days then it returns again, I triple checked it wasn't a refurb
    cartridge, it isn't, it's a brand new HP OEM cartridge.
    Any ideas?
  • prntrfxr
    • 1622
    1. Update firmware
    2. Clean and check HVPS contacts from power supply to contacts are not damaged. Replace as needed.
    3. Replace HVPS.
    4. Replace DC controller
    Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
    • Wild Bill
      • Jul 2005
      • 774
      Stop before fuser to make sure where its happening; Try Changing fuser temp settings I would try the transfer roller also
      Izzy
      • prntrfxr
        • 1622
        Wild Bill has some good ideas, certainly the half page test for troubleshooting and the transfer roller. Some fuser temp issues have been resolved with a firmware update.
