HP CM3530 MFP - Cyan background (50%) over whole page
  • Brett207
    • May 2011
    • 35
    Just over 1 year old and out of HP Warranty. This device outputs every colour page (except Black mono) with a heavy cyan overtone. New OEM cartridge made no difference.
    I have observed operation with the front door open and interlocks cheated, and I can see the cartridges all do the developer disengaging action during a print run. My first guess is a high voltage power supply or developer bias problem, or perhaps the pre-exposure lamps.
    This device is located over 3 hours drive away, so it would be nice to return to the site with some extra ideas,
    Anyone else seen this?
    Cheers,
  • JustManuals
    • Jan 2006
    • 9838
    This Parts & Service manual can be purchased for $12.77 and downloaded immediately after payment from http://www.justmanuals.com
    Paul@justmanuals.com
    • prntrfxr
      • 1622
      Not familiar enough with this printer yet (have yet to see one in person). Can you post samples preferably using the PQ troubleshooting pages from the Diagnostic menus?
      Before going any further perform an engine test to bypass the formatter (Try it with the formatter in and with the formatter out. With the formatter out the display will be dark.) Upgrade firmware.
      From what you're telling me, off the top of my head, I would look at: 1) High voltage contacts to the drums, 2) Affected toner cartridge (you already did this one), 3) replace HVPS (maybe in one board on this machine, I'm not sure), 4) DC controller (some machines this is part of the power supply, I'm not sure on this machine).
      • austonrush
        Sharp & HP Tech
        • 234
        Almost guaranteed to be dirty contacts between the HVPS and the Toner cartridge. Pull the machine apart and clean the HVPS contact point and all contacts that lead to the Cyan toner. If this does not resolve the issue replace the HVPS or the machine whichever is cheaper
        Cheers,
        • mabawser
          Tech
          • Sep 2009
          • 121
          had similar issue but it was outputting a complete black page, there are 2 HVPS boards ont his machine.
          one if my memory is called the low HVPS. agree with brandon55, change HVPS and this hopefully will solve your issue. Just to add I tried cleaning the contacts but it made no difference whatsoever.
          cheers
          • prntrfxr
            • 1622
            You might also check the drive gears for that color. If there is a problem with the drive gears it can also cause this type of problem.
            • Brett207
              • May 2011
              • 35
              Re: HP CM3530 MFP - Cyan background (50%) over whole page
              Hello,
              Replaced the lower High Voltage PCB with one out of a good printer
              Fixed.
              Put Dud PCB on other printer... no problem. It works too....
              Swapped them both back - now both working.! Awesome.
              Suspect it must have been dirty or loose HV connections
              Device has been back at the customer for 3 weeks now, and all working fine.
              • austonrush
                Sharp & HP Tech
                • 234
                Congrats on the repair! .
