HP 5200 NT
  • GeoR
    HP 5200 NT
    Hey guys, I need to know how to replace the fuser unit in an HP 5200NT, since this will be my first time working on this model, and I'm not sure if i get to the fuser from the front or the rear of the machine. Any instructions on how to replace the fuser unit would be appreciated. (Telling me to buy a service manual, is not helpful and is just a waste of your time, so don't do it unless you're incapable of giving helpful advice).
    Thanks,
    GeoR
  • jonezy999
    just one copy??
    • Feb 2010
    • 952
    Re: HP 5200 NT
    Thanks,
    GeoR
    You sure ya don't want the manual. All the answers u need are there.
    I have not failed. I've just found 10,000 ways that won't work. ~Thomas Edison
    • JustManuals
      • Jan 2006
      • 9838
      Re: HP 5200 NT
      And it will be helpful when you make a mistake and then get another error when you power it up.
      • prntrfxr
        • 1622
        Re: HP 5200 NT
        One of the easiest you will ever replace. Remove right side cover, lower back cover/duplexer (depending on model), face up bin, and 2 screws. Slide it out toward you.
        • Wild Bill
          • Jul 2005
          • 774
          Re: HP 5200 NT
          Buy the service manual too
          Izzy
          • GeoR
            Re: HP 5200 NT
            Thanks for the help guys, I really appreciate it.
            GeoR
