Color LaserJet 2550.
  • Ingranaggio_rotto
    • Oct 2010
    • 274
    Hello all!
    You can reset the drum?
    And, if so, what is the procedure?
    Thank you!
    • 22930
    Re: Color LaserJet 2550.
    Changing the drum will reset the light, unless it's a non-OEM drum unit. To continue printing with a non-OEM dum unit press the Cancel Job button.
    Otherwise, you may have an error condition using a combination of display LEDs to indicate a specific error. The best thing you can do is purchase a manual, so you can determine which error condition you have. =^..^=
