HP LJ4600 PDF and Duplex
  • craigb
    Have a LJ4600 , when printing PDF's only, multipage docs will duplex no matter what driver settings.Word etc works fine.Any ideas would be appreciated
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    Re: HP LJ4600 PDF and Duplex
    have you removed your drivers and reloaded them? Drivers are free, and that makes it the first place to start when working on a communication problem.
      • 22997
      It's usually Microsoft Office apps that save print driver settings in the document. My suggestion is to open the document in Adobe Professional, change the driver settings, and Save. From then on the document should use the new settings. =^..^=
      • prntrfxr
        • 1627
        Try updating firmware. Usually solves most pdf issues.
        Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
