It started with the 24:10. The book said to run the broken bag detect program and I did.
I got more error codes. 13.2:10, 1.2:10, 1.0:10 & 26.2:10.
I reseated connectors on the Gamut bd and ran the test again. Same result.
I powered it down and then on and that's when the power would not stay on.
I checked the fusers on the mech bd. The seemed ok.
The lights on the mech bd that are off are the 24Vs and Vpower 2.
The book only sez replace the power supply. Can some one shed some more
light on this problem please?
Also I did look at the ink station and found yellow ink in the air lines to all inks
except the magenta. I removed the lines and flushed. There was a slight
amount of ink around the base of the yellow ink cartridge receptical, but
not so much that it could be seen from just openning the front access door.
DR
