HP CLJ 4600 pick up paper continuously non stop
  • brianho80
    • Sep 2009
    • 198
    Hi Expert,
    my HP CLJ 4600 seem like keep picking up paper without a pause.
    for example, like normal printer processing job, pick up roller will turn 1 round to push the paper to cassette roller and convey to image belt.
    i wonder why this pick up roller keep turning; paper is not fully goes into image belt yet, it had turn 2 round on the same paper.. Does this right?
    somehow i was printing one page but it pull 2 papers up which second paper causing the jam.
    does anyone have this problem before?
  • Wild Bill
    • Jul 2005
    • 774
    Re: HP CLJ 4600 pick up paper continuously non stop
    It is possible that the feed solenoid is getting stuck. IDK if this is the same as like a 4200/4100 and such but they have a solenoid that have foam that gets old and sticky and causes the solenoid to stick and keep feeding. You can fix by cleaning old foam and applying Electric tape; Or by a new solenoid;
    Note:If you dont put the tape it wont work right.
    Izzy
      • 22917
      ditto Bill.
      The old sticky foam can cause it. And removing the foam can do it. If you just leave the metal bare it will magnetize, producing the same effect.
      I have a single hole punch and punch out 6mm disks of rubber (recycled bicycle inner tube). Adhere it with superglue.
      • JustManuals
        • Jan 2006
        • 9865
        Paul@justmanuals.com
        • prntrfxr
          • 1627
          Replace the pick-up asm or replace the solenoid for tray 1. The solenoid is in the pick-up asm, which feeds paper for tray 2 and tray 1. The paper tray has the mp roller and sep pad in it. You might want to check them for wear as well.
          Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".
          • brianho80
            • Sep 2009
            • 198
            Hi everyone,
            Manage to settle the issue by cleaning up the sticky foam on the two solenoids.
            Its runnning normal currently with pause after pick up first paper and continue after first paper goes up to image belt..
            Thanks everyone for the advise.
