HP LaserJet 4700dn All Blue Pages
  • nogood boyo
    • Mar 2012
    • 156
    Switched drum and toner cartridges, new image transfer unit.still printing all blue on everything.?
    • 23010
    Re: HP LaserJet 4700dn All Blue Pages
    I see a pattern interval. Do you? ~70mm I'm guessing. And the other clue: The cyan has no voids defining the edges. You've got cyan primary charge loss. My guess? You've got a defective cyan laser cartridge. It will remain defective in whatever slot you install it in. =^..^=
    • nogood boyo
      • Mar 2012
      • 156
      charge loss was my first guess... it dumps toner all over the ITB and gets all over the back of the piece of paper as well... the toner that spills over on the back doesn't fuse to the paper at all and gets all over your hands./i haven't worked on one of these machines yet and i was thinking DC Controller?
        • 23010
        Start with the cyan toner cartridge. 95% of the quality problems on color HP come down to the cartridges. =^..^=
        • Wild Bill
          • Jul 2005
          • 774
          Take the cyan cart out and run Disable cartridge check (special mode test) This diagnostic test can be used to isolate print quality problems that are
          related to individual cartridges and to isolate individual cartridge problems, such as noise.
          Izzy
          • JustManuals
            • Jan 2006
            • 9838
            http://www.justmanuals.com
            Paul@justmanuals.com
            • nogood boyo
              • Mar 2012
              • 156
              definitely not the cartridge... i just swapped cartridges and it did the same thing... i even tried a cartridge of a different colour from the same machine to see if it would have any effect, magenta does the exact same thing.
              • bernz
                i think you have a toner problem, try to replace the PCR if the problem still appear then replace the upper part of the cartridge "the waste bin"..
                • Wild Bill
                  • Jul 2005
                  • 774
                  Was there a resolution to this...Like to know
                  Izzy
