It started as a jam issue. I found a guide in the tray and removed the feed assembly and reinstalled it. It still jammed out of the tray, looking like something was hitting the paper. Paper never leaves the tray. I open the bypass and it feeds. I left it working and left. I return next day to troubleshoot. They have a second 4700 that has not been used in a while, so I pull the feed assembly and put in my problem machine. It jams. Each page weather from the #2 tray or bypass gets to just above the media sensor, just coming in contact with the belt enough to leave a trace of toner on the edge of the page. I put the old feed assembly back in and now it jams from the bypass in the exact same spot. I took a shot and ordered another feed assembly. Went back today and installed the new one and it does the same thing, tray or bypass stops just a mil or 2 above the media sensor. At this point I have to assume it is the electronics. I took my new feed and put it in the other printer to check it before I started pulling the boards out of it. I got the same result. Tried 2 of the 3 assemblies and it stops at that same point every time. Machine will not pull to do a paper path test. I swapped the transfer belts and the yellow cartridges. So now I am stumped. What are the odds of the same electronic problem on two different machines? Any ideas?
Also the belt and the cartridges are turning.
