Designjet 500 making pretty wallpaper.
  • fixthecopier
    ALIEN OVERLORD
    • 4714
    It does this on at least 1 out of every 3 pages. These samples are the config page printed from the internal memory, so drivers not an issue. The samples are supposed to be b&w.
  • RRodgers
    • Jun 2009
    • 1950
    Re: Designjet 500 making pretty wallpaper.
    Bad ribbon cable I would think.
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      I did not think of the ribbon, why would you thnk it is the problem? After talking to a different person today, I was told that it was sent 5 prints to do, and after the third one it started this and is on every print now.
      • Rob Sandberg
        • Jul 2008
        • 275
        It is high failure part.
        The ribbon is always flexing causing the failure rate.
        I may be wrong but I think this is a paralle connection, so if a trace is broken than the transmision is screwed up.
        This could produce what you are seeing.
        Besides it costs less than a formatter board.
        Rob S
        • fixthecopier
          ALIEN OVERLORD
          • 4714
          Sounds logical. I will order a new one and let you know if it works. Thanks for responding.
