need some insight
  • luis8832
    • Dec 2008
    • 250
    [Error Code] need some insight
    Working on a HP 4015tn. Customer called in with a 50.3 fuser error. We ordered the fuser and replaced it. Still has the same code. Any insight would be greatly appreciated.
  • Jude
    • Oct 2009
    • 257
    Re: need some insight
    Turn the printer off, wait
    20 minutes, and then turn
    the printer on.
    If the message persists,
    reseat the Fuser. If that
    does not work, replace the
    Fuser.
    To check the Fuser, turn
    the printer off and remove
    the Fuser. Measure the
    resistance between the
    Fuser connectors J132-1
    and J132-2. If it is not within the
    range of 200kW to 500kW,
    replace the Fuser.
    If there is no continuity
    between the Fuser
    connectors J143F
    (neutral) and J142F (hot)
    with the Fuser removed,
    replace the Fuser.
    If the problem is not
    related to the Fuser,
    replace the Engine
    Controller Board
    • Wild Bill
      • Jul 2005
      • 774
      Before I replaced The power supply I would try another fuser assembly. If you have another machine close by just to make sure its not a defective.
      Note: Always update firmware
      50.3: High fuser temperature8. If the error still persists, replace the highvoltage
      power supply.
      Izzy
      • Iowatech
        Not a service manager
        • 3933
        That's a fuser overheat error, and all the manual says is to make sure you have the right fuser in the machine. The 110V fuser is part number CB506-67901, the 220V one is part number CB506-67902.
        Was the fuser warming up? If not, you might have a dead DC controller, which I believe is part number RM1-4582-000CN. You probably should price that before you replace it, and if you do replace it, refer to the manual as there is a very specific procedure to do that.
        Other than that, clean the connector on the machine and the fuser unit, and unplug the machine for around a half hour to reset the power supply (at least the half hour was how long we waited to let the power supply reset on some of the machines after a power surge).
        • JustManuals
          • Jan 2006
          • 9919
          Paul@justmanuals.com
          • luis8832
            • Dec 2008
            • 250
            Thank you all for your advice, greatly appreciated! Will try the troubleshooting tomorrow when I get back into the office.
            • luis8832
              • Dec 2008
              • 250
              Also will keep you posted.
