customer claims that 2 time in last couple of weeks the machine instructed her to change cartridge though she had only just changed within a week. When I went there machine was working and customer they had thrown out the two cartridges so I could not inspect them. Uses OEM. Any thoughts? Frank/ActionPhotocopy
LJ 4300Tn "change cartridge" message thought customer changed twice in last 2 weeks
Re: LJ 4300Tn "change cartridge" message thought customer changed twice in last 2 we
Perhaps poorly re-programmed chips on re-filled cartridges? I've never gotten a bad chip on an OEM, but that's what it sounds like. =^..^=If you'd like a serious answer to your request:
blackcat: Master Of The Obvious =^..^= -
Thanks David. That is something to consider when I speak with Company contracting me to service their cusomers' machines and they supply the cartridges which are remans. FrankComment
It is the chip on the cartridge 99% for sure unless the printer has a rare malfunction of reading the chip properly. Only way to know for sure is installing an oem cart to see if problem never comes back. Chips from a few of the common aftermarket suppliers such as Static Control or Future Graphics are very reliable. Ive used thousands of them without issue in my previous career. Some chips are dedicated for specific cartridge models and some are universal. Universal chips are normally in two versions between printer models as standard yield and high yield. There are many HP models that use the same physical size/shape chip as an HP 4300 chip so it could be possible someone put the wrong chip on it.
Sent from my DROID BIONIC using Tapatalk 2Comment
Is the contractor a remanufacturer or do they outsource their product? Reason i ask is because most good remanufacturers of laser cartridges would know better than to contract a third party repair tech before verifying an issue like this.
I don't know if they reman the cartridges themselves. They are in another state and cannot provide the service themselves so they subcontract. I was surprised that the customer had thrown away the cartridges as I would have instructed them to hold onto them for the serviceman or have them returned.
I was also at customer's office for a LJ P4515 with spots /splotches on oneside. This turned out to be toner dropping from right side of drum because of faulty cleaning by blade. After swapping all was well. It was a cartridge that had been changed very recently so there are clearly some reman issues. I will be speaking to them to make sure they understand that there is a reman problem. FrankComment
