HP 5200 loud knocking
  • skinnypuppy
    CopierJanitor/Geargluer
    • May 2008
    • 92
    A client has an HP 5200 with a loud knocking noise. This sounds like it is coming from the drive section (which I have removed) and the gears seem a bit worn but nothing broken. There is still a feed and transfer drive section in the machine that I have not yet removed? I have tried different cartridges in it and still the same and have put the cartridge from this machine in another unit and it works fine. Any Ideas?
    The knocking noise begins after initialize at power up.
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP 5200 loud knocking
    This Parts & Service manual can now be purchased for $12.77 and downloaded immediately after payment from:
    Paul@justmanuals.com
    • jtymabel
      • Aug 2008
      • 164
      Fixing unit ?
      • skinnypuppy
        • May 2008
        • 92
        I think I am focusing on the drum drive section, the large 133 tooth gear (coupling gear) seems to have quite a bit of play in it on the shaft, I noticed there are main drive unit gear rebuild kits available. Anybody have any experience with this problem?
        • HenryT2
          • 962
          I'm not that familiar with all HP ....... but, some of the older ones 4250's , etc, had a 'Swing Arm Assembly' that would need to be replaced, and it made a very loud knocking noise when it was broken .....
          Good luck .....
          "The Serenity Prayer" . . .
          God grant me the serenity to accept stupid people , the courage to not waste my time and energy on them , and the wisdom to know that I cannot fix STUPID .
          • kannuki2
            • Feb 2012
            • 398
            buy this and it will solve all the noise problem
            Airsoft Ear Plugs (1 pair)(with cord-: Amazon.com: Industrial & Scientific
            • Rob Sandberg
              • Jul 2008
              • 275
              How old is the printer?
              How old is the fuser?
              Have you replaced the fuser?
              Does the printer sit for long periods of this with out use?
              I would change the fuser first before anything else.
              Rob
              • fbkhan3
                • May 2012
                • 421
                HI
                had one of these few weeks ago.Replace the First Tray(By Pass tray)drive/coupling gear(Tiny spring in it) which drives the first feed Roller,
                right side when you open the front door!
                HTH!
                • servicemax
                  • Dec 2012
                  • 7
                  If the noise seems to be coming from the left mid/left rear side, you probably have a weak fuser drive gear assembly.
                  Call Liberty Parts Team, Rich Russell and ask for part# gear-5200-gr-nn.
                  This kit has several gears that are all related. Also get the gear on the fuser that mates with the kit gears: RU5-0556.
                  Rich can help.
                  • kannuki2
                    • Feb 2012
                    • 398
                    here's the bulletin on how to replace the fuser drive gear.
                    • skinnypuppy
                      • May 2008
                      • 92
                      Problem solved
                      It was a main drive gear issue in particular the 133 tooth gear and the double intermediate drive gear that matches up to it. It seems that a small amount of wear in either of these gears is enough to cause this problem.The shaft that the 133 tooth couple gear sits on is about 1cm long and as the gear rides up to couple the drum unit it relies on the cam and bushing that the coupler sits in, to keep it centred. After removing the intermediate gear if you run your fingernail up and down the main helical gear of this double gear you will feel a difference in height, on a new gear this is not present.
                      • HenryT2
                        • 962
                        Glad you got that fixed ... thanks for letting us know what corrected this problem .
