HP 4200 - Tray#2 Jammed
  • kannuki2
    • Feb 2012
    • 398
    Problem: Tray#2 jamming only when there are 4 or 5 sheets left in the tray.
    Other Symptoms: Paper end sensor detects when there is no paper in tray 2. I can run the machine flawlessly when fill the tray to half way or max. I ran it through tray#1 fine. So I'm pretty sure there is nothing wrong with relay or registration section.
    So far, I have replaced the entire paper tray #2 and still no help.
    Any suggestions would greatly appreciated.
    • 23008
    Re: HP 4200 - Tray#2 Jammed
    Jam code? =^..^=
    • kannuki2
      • Feb 2012
      • 398
      Jam code? =^..^=
      Jam code 13.1
        • 23008
        followed by a "41.03 UNEXPECTED PAPER SIZE"? Dirty registration sensor. =^..^=
        • jtymabel
          • Aug 2008
          • 164
          the feed solenoid could be sticking. there is also a paper sensor right behind the mp tray. part number in the diagram is 16. (maybe hard to see)
          • kannuki2
            • Feb 2012
            • 398
            I will try the solenoid tomorrow. But I just want to confirm about the solenoid for tray #2.
            here's the below site depict it.
            LaserJet 4200, 4300 Internal Parts Diagram 2
            Are you talking about the sensor on image #7 of the parts catalog on the above website?
            • jtymabel
              • Aug 2008
              • 164
              part number 17 for solenoid and yes on the sensor. usually the flag / spring that trips the sensor is at fault.
              • Yeeter
                • Nov 2012
                • 14
                +1 on chasing this sensor functionality. If it hangs up it doesnt trip at the right time.
                • kannuki2
                  • Feb 2012
                  • 398
                  Updates: it turned out that
                  WC4-5139 Cover, Top cover interlock access switch
                  is loose. Problem fixed. thanks guys.
                  • servicemax
                    • Dec 2012
                    • 7
                    Remove right cover and 1 screw to get to tray 2 solenoid.
                    Replace solenoid damper pad with suitable pad.
                    Note that there is VERY LITTLE room for a thick pad here.
                    If pad is too thick, solenoid lever will not clear cam when energized.
                    Also, I clean rollers behind tray 1 assembly with rubber cleaner, and clean paper pass sensor here too.
                    You have to also consider that tray 1 runs slower than tray 2.
                    If paper is slipping in the fuser, it will cause timing issues.
                    I have seen reman fusers do this so much that I will only use OEM HP.
