No more "Storage" options in print driver for HP CLJ CM3530
  • aab1
    End User
    • Oct 2010
    • 305
    I think it's when I still had my CLJ 3530 connected by USB I had the option to store a print job on the printer itself so I can then print it in a few clicks from the machine rather than go through the computer.
    I've since connected it by network which caused a slight problem with prints not being aligned or centered but I just recently noticed I also no longer have the options to store print jobs on the printer.
    I assume this is because I have the wrong driver installed? How do I at least fix the missing job storage options, which may fix the alignment too if it's also a driver problem.
    • 23009
    Re: No more "Storage" options in print driver for HP CLJ CM3530
    Take a look at the configuration page. I'm willing to bet that this newest machine does not have the J8018A or J8019A Hard Drive option. No HDD means no storage. =^..^=
    • aab1
      End User
      • Oct 2010
      • 305
      I never changed the machine, only the driver and connection method (from USB to network).
