I can cycle the power, but code returns. I replaced the fuser 6 months ago, 60K, because it split apart. Wondering if something besides the fuser could cause this? I did update firmware without luck.
HP 4015dn shows 50,2 fuser error
Re: HP 4015dn shows 50,2 fuser error
Paul@justmanuals.com -
If you used rebuilt, it just failed. Replace it again.The greatest enemy of knowledge isn't ignorance, it is the illusion of knowledge. Stephen HawkingComment
thec3llc
There is also the possibility that it's the high voltage power supply.
Sent from my SCH-I605 using Tapatalk 2Comment
thec3llc
Just an FYI:
High voltage power supply relates to transfer rollers and cartridge.
Low voltage power supply relates to fuser
Fuser is the 1st check for this problem.
Power Supply is the 2nd (lvps and hvps are in one board for this machine
krm,
Thanks for posting what fixed the problem.Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well-preserved body, but rather to skid in sideways - Coke in one hand - chocolate in the other - body thoroughly used up, totally worn out and screaming "WOO-HOO, what a ride!".Comment
