HP 4015dn shows 50,2 fuser error
  • krm
    • Aug 2009
    • 233
    I can cycle the power, but code returns. I replaced the fuser 6 months ago, 60K, because it split apart. Wondering if something besides the fuser could cause this? I did update firmware without luck.
  • JustManuals
    • Jan 2006
    • 9838
    Re: HP 4015dn shows 50,2 fuser error
    Paul@justmanuals.com
    • fixthecopier
      ALIEN OVERLORD
      • 4714
      If you used rebuilt, it just failed. Replace it again.
      • krm
        • Aug 2009
        • 233
        yeah, that sounds logical. I've ordered it and will reply with result.
        thanks.
        • thec3llc
          There is also the possibility that it's the high voltage power supply.
          Sent from my SCH-I605 using Tapatalk 2
          • krm
            • Aug 2009
            • 233
            I replaced fuser on Thursday and so far, so good. Must have been a bad fuser.
            • thec3llc
              Good deal.
              Sent from my Samsung Galaxy Note 2
              • prntrfxr
                • 1626
                thec3llc,
                Just an FYI:
                High voltage power supply relates to transfer rollers and cartridge.
                Low voltage power supply relates to fuser
                Fuser is the 1st check for this problem.
                Power Supply is the 2nd (lvps and hvps are in one board for this machine
                krm,
                Thanks for posting what fixed the problem.
